Originally Posted by turborattler
Coil is new wires are new they all are firing just got 2 codes show up p0507 and p1166 Ist and Maf are new think it could be the rear cat idling I can put my hand over exhaust pipe and stop all air from coming out
Greetings,
If you haven't already, recommend signing up at the kiatechinfo website (see my sig.) using Internet Explorer web browser (see reqs. main page), then you can look at the [Service Info] for your vehicle & also search the online system to look at the diagnostic tree(s) for the DTC codes you are getting:
P0507 - Idle control system RPM higher than expected:
• Short to ground between IACV and ECM
• Air leak in intake system
• Improperly adjusted accelerator cable
• Faulty IACV
• Faulty TPS
• Faulty PCV/PSV
HO2S-Controller Adaptation Diagnosis Malfunction
• Fuel system malfunction (fuel tank/pressure regulator/fuel pump/PCSV)
• Poor connection to fuel line hose/sealing/cut
• Sealing between PCSV and fuel tank
• Air leakage in exhaust system
• Ignition system malfunction (ignition coil, spark plug, cable)
• Faulty surge tank and intake port
If any codes relating front/rear HO2S, fuel system, EVAP, and ignition system are present, do all repairs associated with them before proceeding with this troubleshooting procedure.
1st code is related to air leak / illegal air, second code is related to fuel system, common denominator between the (2) would be the Purge Control Solenoid valve -> EVAP system: would recommend Q/A'ing the Purge control solenoid valve & hoses going to the Intake Manifold..
Hope this helps,
GottaCruise
