p1166, 2002 rio - Kia Forum
post #1 of 9 (permalink) Old 07-26-2010, 02:31 PM Thread Starter
dgd
Drives: 2002 kia rio
p1166, 2002 rio
Ok, I have been researching this helpful site to fix my daughters car. Engine was replaced ( junkyard-47,000mi I was told) car has 125,000 mi. She has put about 8,000 mi. on it since last year. Idle has been getting rougher and now throwing 1166 code. I see that there could be many reasons. Most of the hoses look good-no sign of cracking. I cleaned mf and iac sensors. I connect or disconnect tps and car runs no differently but local dealer says he doesn't stock them because he never sells them. My daughter is becoming annoying. Please help or take my daughter.
dgd is offline
post #2 of 9 (permalink) Old 07-26-2010, 02:57 PM
Drives: 1999 Kia Elan
Quoted: 383 Post(s)
Welcome to the forum.
We'll need to see photo's !
That codes implies that there's a lean condition.
Possible causes:
1) Vacuum leaks.
2) Leaking PCV valve.
3) Leaking EGR.
4) Dirty or bad MAF
5) Intake pipe between MAF and TB leak.
6) Low fuel pressure - fuel filter plugged - dirty injectors
The MAF is very delicate, and should only be cleaned by spraying on something like non-residue electrics cleaner - don't touch it with anything.
ron1004 is offline
post #3 of 9 (permalink) Old 07-26-2010, 04:32 PM Thread Starter
dgd
p1166
What would you like photos of? I used electronics (crc) cleaner on all sensors. How do I narrow these options down or test each item. These sensors are expensive to replace trial and error. Thanks for your help!
dgd is offline
post #4 of 9 (permalink) Old 07-27-2010, 02:56 AM
hktan73's Avatar
Drives: KIA RIO 2003 5 door Auto
Think he meant photo of your daughter!
hktan73 is offline
post #5 of 9 (permalink) Old 08-15-2010, 07:28 AM Thread Starter
dgd
rough idle
You wouldn't want a troublesome rio and troublesome teenager! Brakes are not functioning either.Sure points to vacume issues. I read thread from mark 458 with exactly same problem but there was not end result to issue discussed. When accelerating there is not enough vacume to operate brakes! Others seem to have related issues. I am still searching. Dealer is useless-trial and error problem solving. I can do that. I replaced plugs,wires,pcv ,cleaned with special cleaners all the sensors. All lines I inspected-look ok. Any more ideas? Thanks
dgd is offline
post #6 of 9 (permalink) Old 08-15-2010, 12:41 PM
Quoted: 383 Post(s)
Smile
You're sharp !
ron1004 is offline
post #7 of 9 (permalink) Old 08-15-2010, 12:46 PM
Quoted: 383 Post(s)
There is a check valve in the pipe between the inlet manifold and the vacuum brake booster, and if it is working it will allow the brake booster to build a reserve vacuum capacity.
Some times the check valve is at fault, but if there's signs of continuous low vacuum, then possible a leak in the vacuum brake booster.
ron1004 is offline
post #8 of 9 (permalink) Old 08-18-2010, 07:25 PM Thread Starter
dgd
Checked valve it is ok. Temp is rising on hills. Thinking this is starting to look like head gasket and or weak compression on cylinder(s). will do compression test with and without oil in cylinder to see if rings or if valve(s) are shot. What is it like to do head gasket job?
dgd is offline
post #9 of 9 (permalink) Old 08-24-2010, 05:15 AM
hktan73's Avatar
Originally Posted by ron1004 View Post
You're sharp !
Wow, is she really that serious? We will really need to see photos! I mean of your daughter!!!
Anyway hows the compression test?
hktan73 is offline
