Blower and AC button not working on 03 Rio. - Page 2 - Kia Forum
post #11 of 18 (permalink) Old 01-02-2010, 03:40 PM Thread Starter
Drives: 03 Kia Rio Cinco
It is happening again. Just a little over a month with the new blower switch, and all of a sudden the heat would not blow unless the knob was pushed in. I took the front console of the car off, and realized that the connector and blower switch was really loose, and the tab that holds it in place was broken. I put a binder clip on there to hold everything in place, but it is still loose, and I can't seem to get it to stay in the correct setting, where all of the settings 1-4 work. It's only working on 4. I really don't want to take everything apart anymore, because I'm afraid I'll break it further, and the heat won't work on any of the settings. The connector and the switch just seem really hot. I'm not too sure if it's the wires in the car, or if the heat/AC control unit is faulty.
khptown is offline
post #12 of 18 (permalink) Old 01-02-2010, 04:28 PM
Rio767pilot's Avatar
Location: Inland Empire, Ca. or Cruzin the skies at 500+
Drives: 2003 Rio
Have you checked your blower motor? Seems to me that the motor is pulling more amps than designed. You might want to check and see if its failing.
Rio767pilot is offline
post #13 of 18 (permalink) Old 01-02-2010, 04:59 PM Thread Starter
At one point, I had the Chevy dealership, where I got the car from and who performs the routine maintenance on in, look at the car, when all of this started, and at that point they said that the blower motor was fine. I never really thought about that as being the problem though. Who would be able to check that, an auto mechanic specializing in electricity?
khptown is offline
post #14 of 18 (permalink) Old 01-02-2010, 05:55 PM
kiario04's Avatar
Drives: 04 Kia Rio (my babe)
Send a message via AIM to kiario04 Send a message via Yahoo to kiario04
Get a volt meter and measure the voltage on it.
never under estimate the power of my RIO:cool:
kiario04 is offline
post #15 of 18 (permalink) Old 01-02-2010, 06:09 PM
Drives: 2003 Rio
Kiario04... I believe you want to check for amps and use your voltohm meter in series with the circuit.
post #16 of 18 (permalink) Old 01-02-2010, 08:47 PM
kiario04's Avatar
correct thats what I ment by that lol but im not familiar with that so I just tried giving the best advice I could. But its all good.
kiario04 is offline
post #17 of 18 (permalink) Old 01-03-2010, 02:10 AM
Drives: 2004 Kia Rio
I have the same problem with our '04 Rio, as I posted about in this thread.
My stepdad owns an auto salvage yard, and after I mentioned this problem to him, he said it's a common problem that he's seen among certain models of vehicle (he's seen the same problem in Tempo's, Oldsmobiles, and others). Essentially it sounds like a design flaw with the affected vehicles that especially likes to rear it's head in cold conditions.
My working theory is as follows. It should also be noted that my stepdad isn't a professionally trained expert persay, but he does have over 10 years experience owning and running his salvage yard and has worked on countless vehicles over the years. I trust and value his opinion. With that said, please take this with a grain of salt, as I said it's just a theory!
Due to the extreme cold weather (ie: below -30 C) experienced in some climates, the unfortunate folks who are forced to park outdoors like to start their car before leaving and allowing it to warm up for 10-15 minutes to a comfortable temperature. On some occasions, life happens and people get delayed getting out to their vehicle and it can end up sitting running for 30 minutes or longer. Additionally, sometimes people wait in vehicles (for example, waiting for a spouse to get off of work) and sit inside with the heater running for extended periods of time. Another example would be a long road trip where the heater is running for hours at a time. NOTE: I'm not condoning any of the above, just observing.
The longer the car is running with the heater going, the more heat builds up in the cavity in behind the heater control switch. Due to a design flaw (lack of proper air flow), this heat builds up to the point of either partially melting the plastic plug that connects to the heater control, or causing heat-related fatigue that eventually causes a connection problem inside the plug.
My stepdad mentioned that the easiest way to fix this is to locate a salvage heater control switch, and also cut the connector plug from the salvage vehicles' wiring harness. Then it's a matter of removing the melted/damaged plug and soldering the new plug to the car's wiring harness. Then with the switch and plug replaced, hopefully this problem will not happen again any time soon. I asked about replacing the entire wiring harness, he said this is definitely overkill for a problem that can be fixed just by replacing the plug.
I had read Rio767Pilot's suggestion to test the current draw on the blower motor, and mentioned this to my stepdad. He said it's definitely a good idea, as extra current draw could be the root cause of the overheating in the first place.
It seems that the best preventative measure for this issue would be to not let the vehicle sit so long unattended (or alternatively, not run the heater for long continuous periods), as to prevent heat build up inside the cavity behind the heater control switch.
I hope this helps!
KiaOwner2004 is offline
post #18 of 18 (permalink) Old 01-03-2010, 04:26 PM
kiario04's Avatar
I hope this helps!
Wow thats a good idea, I never thought of that before. Well I have a solution to that problem. Get two small fans, i.e. computer fans and place them behind the heater control unit and but have them blow the air towards the doors. This will help pull the hot air from the unit and keep it cool. If you want for some lighting effects as well, Simply get fans that have the lights built into them so when you start the car the fans will turn along with the lights and the unit. I might go out and try this out. if you hook it up to the unit as in acc. and ground, you wont even have to run a switch to it.
kiario04 is offline
