P0101 sensor or filter? - Kia Forum
post #1 of 10 (permalink) Old 09-23-2009, 02:15 AM Thread Starter
kiario04's Avatar
Drives: 04 Kia Rio (my babe)
Send a message via AIM to kiario04 Send a message via Yahoo to kiario04
My cel has come back on a few times after i have reset it. I have cleaned the maf sensor twice already and it comes back but it onlt does when i get on the highway. I have a k&n cone air filter and I heard that if the filter has to much oil on it that the excess oil will come off the filter and hit the sensor contaminating it. I reset the ecu, cleaned the sensor and allowed it to dry over night and went out for a while but i didnt go on the highway. I went to a local shop (that I trust) and had the ecu checked out and it that sensor came up as ready (working correctly). I got on the high way after that and the cel came on and displayed P0101. I put about 50 miles on it from resetting the ecu to getting on the highway. Now the day after, I cleaned the sensor again and reset the ecu, drove around adding about 10 miles before I got on the highway. Once I got on the highway, it came back on. Ironicaly the same general area as well. I was thinking that considering that I havent cleaned the filter in 5 months, the dirt maybe coming off the filter and contaminating the maf when I get to highway speeds. So, im debating on getting a new filter and getting the code erased from the ecu. If I get the code erased, will it come back up if the filter didnt fix the problem o will it as if the maf doesnt exist anymore.
never under estimate the power of my RIO:cool:
kiario04 is offline
post #2 of 10 (permalink) Old 09-23-2009, 06:31 AM
Rio767pilot's Avatar
Location: Inland Empire, Ca. or Cruzin the skies at 500+
Drives: 2003 Rio
Had this problem a couple of times... The cure for me was the Kia TSB #Kt200510053 (Throttle Body Cleaning). Your computer might be compensating for reduced airflow. Go to the Kia website and research.
Rio767pilot is offline
post #3 of 10 (permalink) Old 09-23-2009, 07:04 AM
Pacosworld's Avatar
Quoted: 13 Post(s)
I think the only way you're going to get rid of that code is to return it to stock.
DTC description for P101: The ECM compares the actual measured Mass Air Flow signal to the modeled Mass Air Flow value and sets the DTC P0101 when the difference between these two value is too high or too low with lambda deviation in opposite direction. The ECM illuminates the MIL on the second consecutive driving cycle that the diagnostic runs and fails.
The modeled Mass Air Flow value is determined by engine speed, throttle angle and ISCA duty.
The ECM is seeing the MAF signal is too high because that is what a cone air filter is supposed to do, bring in more air. During city driving, the value is higher than normal, but not enough to light the CEL. During highway driving, its way out of specs and lights the CEL.
Mike AKA Paco
Pacosworld is offline
post #4 of 10 (permalink) Old 09-23-2009, 09:27 AM Thread Starter
kiario04's Avatar
True but when I purchased the car, I put it on and it gave me no problems for about a year and a half.. It just started doing this after you cleaned the filter.
and for the high and low, the codes P0102 and P0103 would come up but they dont.
kiario04 is offline
post #5 of 10 (permalink) Old 09-23-2009, 09:29 AM Thread Starter
kiario04's Avatar
So just get some throttle body cleaner and wipe down the walls of the tb?
kiario04 is offline
post #6 of 10 (permalink) Old 09-23-2009, 11:17 AM
Drives: 2003 Rio
Yes sir....
You will see the residual around the throttle plate and the bore. If you never cleaned it before, it might have a little ring around where the plate and the bore meet. It might take a little extra cleaning in this area.
post #7 of 10 (permalink) Old 09-23-2009, 03:08 PM Thread Starter
kiario04's Avatar
Yes sir....
hahahaha well I whope that fixes the problem due to the fact that I have never cleaned out the tb since I first bought the car about 3 years ago.
kiario04 is offline
post #8 of 10 (permalink) Old 12-14-2011, 03:44 PM
Drives: 2003 kia rio
Having the same problem here....
Already replaced MAF and filter. So cleaning the TB will fix this?
blackjack is offline
post #9 of 10 (permalink) Old 12-14-2011, 05:19 PM
Quoted: 29 Post(s)
Maybe, give it a try it sure wont hurt to do it. Also don't forget to clean the IAC valve also while your at it. Use carb spray on the TB and the IAC it might make a difference. Don't use carb spray on the maf, use maf cleaner it has to be a non residue cleaner the sensor doesn't like that, advance auto has a can at 5 or 6 bucks. Kia Global Information System (KGIS) to help with your problem. Good luck with it and keep us posted
ronjohn is offline
post #10 of 10 (permalink) Old 12-14-2011, 08:28 PM
Kevster's Avatar
Drives: 05 Durango, 2012 Kia Soul+
There is a service bulletin to reprogram the ECU (04 models) to correct this. I had this issue in my Rio and the PO101 kept coming back, so I had the dealer reprogram the ECU, and then the codes went away, but then the car idled goofy(once warmed up) until I replaced my IAC valve. Everything worked great after that.
Make sure there are no vacuum leaks, they will cause the 101 and some others to come up....
Kevster is offline
