2001 kia rio fuel pump ground wire location - Kia Forum
Old 02-11-2008, 08:29 PM   #1 (permalink)
dennisspeaks's Avatar
Default 2001 kia rio fuel pump ground wire location
can someone provide a picture or tell me where the grounding wire for a 01 kia rio is, sometimes I have to recycle the ignition several times before the car will start. thanks. Dennis
dennisspeaks is offline   Reply With Quote
Old 02-12-2008, 01:17 AM   #2 (permalink)
Drives: 99 Mercury Villager, 96 Chevy 4x4
Go to this site for the 01 Service manual:
http://www.kia-forums.com/do-yoursel...e-manuals.html
Take out the back seat and remove cover to get to fuel sensor for testing.
tempfixit is offline   Reply With Quote
Old 02-13-2008, 05:43 PM   #3 (permalink)
That Link Doesn't Work For Me Mate . . .
TB+JS is offline   Reply With Quote
Old 02-13-2008, 07:45 PM   #4 (permalink)
Sorry that didn't work try this:
http://msw.kiausa.com/default.asp
Good Luck
Old 02-14-2008, 05:48 AM   #5 (permalink)
I didn't find it on the second link and the first one didn't work, please advise. thanks
Old 02-14-2008, 10:21 AM   #6 (permalink)
Go to FUEL SYSTEM, click on it. Then click on FUEL DELIVERY SYSYTEM. Click on FUEL TANK. Then click on REPAIR PROCEDURES:
REMOVAL
1. Disconnect negative battery cable.
2. Remove rear seat.
3. Remove fuel pump cover, and then disconnect fuel pump connector.
4. Remove components in the order shown in above figure.
FUEL TANK PRESSURE SENSOR
1. Reconnect tank pressure sensor connector.
2. Vent fuel tank by removing fuel filler cap.
3. Turn ignition switch to ON position.
4. Using voltmeter, measure voltage at all three(3) fuel tnak pressure sensor terminals in the fuel tank sending unit connector.
3(W)-2.0~3.0V (Signal return voltage/base reading)
5. If signal voltage reads 5.0 volts, check the sensor ground wire.
1(BR)-0.0V (sensor ground)2(L)-5.0V (reference voltage)
6. Disconnect hose from fuel tnak at evaporative emissions canister.
7. Connect hand-held vacuumpump to hose.
8. Connect voltmeter between fuel tank round and the W wire in the fuel tank sending unit connector.
9. With ignition switch in the ON position, verify than voltage goes down when vacuum is applied to when pressure is applied.
10. Disconnect fuel tank pressure sensor connector, then remove the retainer nut, and remove fuel tnak pressure sensor from the tank.
11. Remove screw attaching fuel tnak pressure sensor ground wire to the fuel tnak sending unit mounting plate.
12. Measure fuel tnak pressure sensor resistance.
1(BR)-3(W) : 5.0~6.0 kΩ1(BR)-2(L) : 2.5~3.0kΩ2(L)-3(W) : 5.0~6.0kΩ
13. If not within specification, replace the fuel tank pressure sensor.
Hope this helps
Old 02-14-2008, 03:11 PM   #7 (permalink)
Thanks, I got it, not being even a back yard mechanic without pictures I don't have a clue. anyone got pictures? Thanks. Dennis
Old 03-01-2008, 03:08 PM   #8 (permalink)
jkamery's Avatar
Drives: 2001 Kia Rio, 2007 Kia Sportage
The ground wire is on the back side of the block facing the firewall, in the middle underneath the intake manifold.
jkamery is offline   Reply With Quote
Old 03-10-2008, 11:02 PM   #9 (permalink)
Is the fuel pump replaceable through access panel in back seat? or does the tank need to be dropped? My fuel pressure went to zip. I had delayed starting and intermittent power loss. Now no start. I've noticed the pump sounds slower and quieter during pressure build up during relay activation.
pezzman is offline   Reply With Quote
