DIY Timing Belt - WARNING Interference Engine - Service Interval - Page 4 - Kia Forum
 2Likes
post #31 of 105 (permalink) Old 05-27-2009, 12:51 AM
So whats the best source for a good used motor ?
Concealed45_1911 is offline
post #32 of 105 (permalink) Old 05-27-2009, 06:05 PM
Drives: Suburban 4X4, Magnum R/T, VW Jetta, Suzuki Aerio, Kia Rio
Ok thanks everyone for the help, I cant log in to Kia Global Information System (KGIS)
I gave it my email and password from this site ? How do you register to this site ?
jljbtm is offline
post #33 of 105 (permalink) Old 05-27-2009, 07:01 PM
Quoted: 3 Post(s)
Please don't take this the wrong way regarding registering with Kia Global, Get your daughter to help you with it.
I'm as dumb as a box of rocks with computers and I get my grandaughters to help me.
Probably dumb as a box of rocks about other things but lets not go there.
jcwit is offline
post #34 of 105 (permalink) Old 06-14-2009, 11:50 PM
Drives: 2003 Kia Rio RXV
03 Kia Rio 1.6L timing belt
I just had the timing belt break in my wifes car. One way to know immediately if you have valve damage is when you try to crank it over it will turn over much faster than normal due to no compression. If this is the case you DEFINATELY have valve damage and you MAY have piston damage. I took it all apart and found that 7 of the 8 exhaust valves were bent but not broken. There were tiny little marks on the top of the pistons where the valves hit them but none from the intake valves. I replaced the valves, lined up the marks on the crankshaft pulley and camshaft pulleys, installed the belt, turned the crankshaft over twice and ensured all marks still lined up. I started it no problem and it idles at 800 rpm and sounds fine but when I step on it there is a hesitation now that wasn't there before but seems to run fine once the revs get up. I checked to make sure I didn't forget any hoses or sensors. If anyone has any ideas please let me know. Thanks.
toolman_111 is offline
post #35 of 105 (permalink) Old 06-15-2009, 04:39 PM
Update
This is an update to the previous post. After driving the car today for a bit there is definately not as much power as there used to be. It idles rougher than it used to and under initial acceleration it bogs a bit. No back fires out the top or back. Before I removed the old belt I counted the teeth on the belt between the marks on the cam pulleys and there were 17. I just checked today and there are 18 between them now, even with the marks all lined up. Not sure what's going on here. How do I find out if I need to advance my intake cam one tooth or retard my exhaust cam one tooth? Thanks!
post #36 of 105 (permalink) Old 08-01-2009, 07:25 PM
kiaracer's Avatar
Quoted: 8 Post(s)
what was your method of puting the belt on? did you have the tensioner loose when you were turning the engine the first 2 times to take the slack out of the belt before you tightened the tensioner bolt? it sounds like your belt is too loose and it's jumping timing.
kiaracer is offline
post #37 of 105 (permalink) Old 08-21-2009, 05:43 PM
can someone please share how you get the 21mm bolt off the crank?
do i need an impact wrench? how can i hold the crank in place to unscrew it? i wish these vague directions said something about it....
any info appreciated.
Rome is offline
post #38 of 105 (permalink) Old 08-21-2009, 07:19 PM
kiaracer's Avatar
Quoted: 8 Post(s)
a strong impact gun will take the bolt out without turning the crank.
kiaracer is offline
post #39 of 105 (permalink) Old 08-24-2009, 08:22 AM
perfect... got an impact wrench at harbor freight for $45 with tax..
got the job done.
car runs great.
Rome is offline
post #40 of 105 (permalink) Old 09-01-2009, 12:26 PM
enough is enough.
Just lost my second KIA car. I had a Sephia 99. Died in 03, Transmission went at 102K Did all recommended service even just had transmission service done at dealership 45 days earlier. Dealer stated required over $5500 in repair work due to it locking up on highway and damaging the lines, mounts and flywheel. Threw car away and got a 03 RIO new. Well that one now has died. 149K did complete all service was due for another belt change soon and guess what lost some teeth on belt on highway engine tore its self up. can not even get wrench to move valves. Dealer again said engine and also trans need to be replaced at $6K. Another throwaway car. Enough is Enough never again another KIA I guess it really does mean KILLED IN ACTION. I do a lot of highway driving and followed all schedules but still problems Should have gotten rid of Rio as first day it was stalling right out of dealership lot. Said it has a few day breaking period. Ended up having to replace a sensor the next week.
Bought a Toyota Corolla 2010. Hope to get more than 200K on it.
rdyradar is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
