DIY Timing Belt - WARNING Interference Engine - Service Interval - Page 3 - Kia Forum
 2Likes
post #21 of 105 (permalink) Old 05-26-2009, 07:30 PM
kiaracer's Avatar
Quoted: 8 Post(s)
make sure the pins on both cams are at 12 o'clock. the "I" on the intake cam should be at 12 o'clock with the pin at 12 o'clock on the intake came and the "E" on the exhaust cam should be at 12 o'clock with the pin at 12 o'clock on that cam also. i can have a picture up in a second if you want.
kiaracer is offline
post #22 of 105 (permalink) Old 05-26-2009, 07:34 PM
A picture would be great !!
So the dots dont mean anything ?
Concealed45_1911 is offline
post #23 of 105 (permalink) Old 05-26-2009, 07:57 PM
kiaracer's Avatar
Quoted: 8 Post(s)
the dots don't mean anything because both sprockets have them on the "E". i just happened to have a couple rio cams and sprockets so i got them out and my wife took a couple pictures to post.
this is what the intake cam should look like...
this is what the exhaust cam should look like...
kiaracer is offline
post #24 of 105 (permalink) Old 05-26-2009, 08:27 PM
Cool, thanks...So when I get them on and aligned is it safe to start it, or will it start just for a few seconds before I put everything else back on just to make sure it fires ?
post #25 of 105 (permalink) Old 05-26-2009, 09:54 PM
Drives: Suburban 4X4, Magnum R/T, VW Jetta, Suzuki Aerio, Kia Rio
oK so I am new here and my daughter has a 2003 Rio with 80,000 miles on it.
I have seen the pics in other posts here and don't want those problems so i am getting the belt kit in the morning and also found some directions.
Just how often does this belt need changing? and how do i know if this is a interference engine or not?
it is 1.6L 2003 Rio
Thanks for the help
Dad
jljbtm is offline
post #26 of 105 (permalink) Old 05-26-2009, 10:02 PM
PLP
PLP's Avatar
Quoted: 294 Post(s)
Just how often does this belt need changing? Is hers due now?
For the procedure refer to KIA TECH INFO - link below. It requires registration, but it is free.
It may be overdue already... If you do not have a receipt or any other confirmation that the belt was replaced - do it now. It is due approx. 60k miles (100k km).
You see what happens whet it gets bad
How often? Every 60k miles.
And BTW. Welcome to the forum. Add some info to your profile so that we will not be asking you every time where do you live, what do you drive...
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #27 of 105 (permalink) Old 05-26-2009, 10:27 PM
suppose to be replaced at 60K, the engine is an interference engine.
a9xs is offline
post #28 of 105 (permalink) Old 05-26-2009, 10:30 PM
Quoted: 3 Post(s)
You say you have 80,000 miles on it correct. If the belt has not been changed, and there is no way of really knowing, its 20,000 overdue for a change. Get that puppy changed.
The 03 Rio's are an interference engine, if you don't want to take my word for it "after all this is the internet" do a search on the Gates belt sight.
I would use a Gates belt instead of an oem belt, also replace the idler pully and tension spring. I'd wait for the next change at 120,000 for a water pump change.
Hope this helps and Welcome to the forum, lots of info and help here.
jcwit
BTW all parts needed are available at Autozone and Advance Auto.
jcwit is offline
post #29 of 105 (permalink) Old 05-26-2009, 10:31 PM
Well I tried it and all it did was backfire once out of the exhaust and once out of the intake. I'm thinkin shes toast !
post #30 of 105 (permalink) Old 05-26-2009, 10:39 PM
PLP
PLP's Avatar
Quoted: 294 Post(s)
it is 1.6L 2003 Rio
Thanks for the help
Dad
Just copied my response from other thread where you asked the same question.
PLP is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
