Check engine light trouble codes - Kia Forum
Old 12-25-2012, 02:48 PM   #1 (permalink)
Default Check engine light trouble codes
Hello,
I have check engine light and scanner showed these trouble codes:
P1123 - Long Term Fuel Trim Adaptive Air System Low
P1611 - request signal - circuit/voltage low
Im not sure what these codes mean exactly. Could anybody help me telling what they mean and what is wrong?
P.S. Merry Christmas
Pofkis is offline   Reply With Quote
Old 12-25-2012, 02:59 PM   #2 (permalink)
Unfortunately OBDII codes are just indicators (highlight the possible system).
Use of a LIVE DATA SCANNER will allow you to check the values and components...
Guessing is just a crap shoot......Philip
aquanaut20 is offline   Reply With Quote
Old 12-26-2012, 05:17 AM   #3 (permalink)
And where can I find correct values? Checked O2 sensor. Hot engine idle 0.1V. And 3000rpm 0.9V. Found in autodata that it must be 0-1V. I will check resistance of other sensor, bacause that I can find in autodata. Nothing more.
Is there any kia orientaden obd software like vag com for vw?
Old 12-26-2012, 11:55 AM   #4 (permalink)
You could shed some light on the problem by advising the Yr, engine model and country of origin... Philip
Old 12-26-2012, 01:46 PM   #5 (permalink)
Drives: 2000 Sportage EX 4x4 A/T, 2008 Harley Davidson Nightrain
Also let us know if the vehicle is running any differently or doing something it wasn't before. It could also help narrow down the problem.
wolf_7669 is offline   Reply With Quote
Old 12-26-2012, 02:50 PM   #6 (permalink)
Oh sorry. Totally forgot that: 2000y 2l petrol 16 valves 128hp 5speed manual 150 000 km on the clock. Germany or Netherlands.
I think it drives the same. Well light is on for a long time now and I drive car just occasionally. Once for 2weeks. I checked sensors resistance. I found that throtle position sensor is bad. Well at least I think it is because according to autodata TP sensor resistance should be 800-1000 ohms when closed and it show 1700ohms. Strangely enough MIL does not come instantly, only after 10-20km.
Old 12-26-2012, 03:00 PM   #7 (permalink)
Hmmm! you are running PETROL, must be in the colonies!! and you have OBDII?
What was the original market for that vehicle??
Provided the back pressure test verified the CATs as OK (taken at front O2 bung,<3psi @2500rpm)
time to connect a LIVE DATA SCANNER.
COLD engine, (KOEO)
AIT (air temp)and ECT(coolant temp) must be with in 2% of ambient temperature
TPS, 0% at stop and rise smooth and steady as throttle is advanced
MAF, 0% with no air flow
Battery, 12.6vdc, fully charged.
Start engine.
ECT, must start to rise and attain and hold 180* at idle and 2000rpm
CL (ECU) must maintain at idle and 2000rpm
MAF, small reading at idle and rise steadily as throttle advances.
O2, (B1S1, precat), must start actively switching with no lean/rich bias...
LTFT, (long term fuel trim), close to 0%, +/-2 is allowable, if more, time to investigate fuel delivery/illegal air
Vacuum, at unregulated manifold port, 19-21”hg..with a dead steady needle, investigate jitter or bounce.
...Philip
Old 12-30-2012, 07:26 AM   #8 (permalink)
Well everything seems good except O2 and TPS. What should be value for tps at idle? Mine showed 12%
O2 (B1S1) - 0.11-12V, not much actively switching. Just by 0.1V This one is definetely bad. Is there only one O2 sensor?
Edit: I checked O2 sensor on other car and now I can see what you meant by "actively switching". O2 sensor is definitely dead. Thanks Philip
Old 01-01-2013, 12:44 PM   #9 (permalink)
Drives: 2000 Kia Sportage 4x4 manual, (Daily Driver)..
On the OBDII scanner software I use here (see my sig) I also show between 11% and 13% at idle, depending on the vehicle..
If yours is similar that may account for the reading: a 12% TPS reading at idle would be in the "normal" range w/ the OBDWIZ scanner software,
(Of course, any suspected issue would warrant further testing on the TPS, which you did do -- was glad to read you found the issue, nicely done.)
FYI & Regards,
GottaCruise
Kia Tech Info site: http://www.kiatechinfo.com
Laptop/USB OBD-II Scanner at Amazon: http://tinyurl.com/3jjf7xz
OBD-II Codes: http://www.obd-codes.com/trouble_codes/
GottaCruise is offline   Reply With Quote
Old 01-01-2013, 04:27 PM   #10 (permalink)
Thanks GottaCruise. I just have no idea what is wrong with the other code (P1611 - request signal - circuit/voltage low) Maybe a cable is rusted somewhere
