Kia Sportage Vacuum Hoses - Kia Forum
post #1 of 8 (permalink) Old 02-15-2011, 05:44 PM Thread Starter
JDG
Exclamation Kia Sportage Vacuum Hoses
I just bought a 2001 kia sportage EX and I need to change the locking hub vacuum hoses in order to get the 4x4 to engage because the previous owner gave me his mechanic's invoice and it sais that the hoses are broken. I'm a complete rookie to 4x4 and kia since my last car was a RWD bmw. Can anyone help me out with some instructions on how to change these hoses and what size of hoses I need to buy to get the job done? Also, it would be extremely helpful if anyone had a diagram of the vacuum system so I can identify the broken hoses easier. Thanks.
JDG is offline
post #2 of 8 (permalink) Old 03-10-2011, 04:48 AM
Default Easy Fix
My Sportage did this about once a year, every year. I thought about getting locking hubs but after I took it to the dealer to repair it a couple times, the problem was always the air hoses that go to the back of the front wheels. They would both crack and break at each end of the hose.
The next time it would not engage, I just turned the front wheels so I could see the back side and sure enough, there is a air line running from a nipple coming out of the inside of the fender well to a nipple on the back side of the wheel drum. Each end of the air hose was broke. I could instantly see a very poor design. The factory air line has a built-in rubber gromet in the middle of the line that goes in a metal bracket that keeps the line in place. But there is no slack and is way too tight when the wheels are turned. This poor design puts too much pressure on the hoses where they hook to the nipples every time you turn the steering wheel just by normal driving. The lines always break right where they attatch to the nipple fittings on each end. Both ends break on both front wheels.
A very simple fix that works. Don't buy the factory assmbly but take the old air hose to a auto parts store and just match up the right inner size with a piece of new hose that comes on rolls. Only cut a piece that is about 6 inches longer and don't hook the hose to the metal securing bracket but just run the line through it. Put a loose fitting zip tie in it's place and leave some slack. This gives the hoses plenty of room to move as the wheel turns back and fourth.
This only takes a few minutes to fix. You don't have to jack up the car or even open the hood, but just turn the wheels sharp to access the lines.
They never break on me now and my 4wd always works. Hope this helps.
davidtena is offline
post #3 of 8 (permalink) Old 03-22-2011, 07:59 PM
Drives: KIA Sportage 2001
Thanks Davidtena, your discription of the problem and the fix was right on the money! Fixed it in 15min. Four wheel drive working again.
Eagle19 is offline
post #4 of 8 (permalink) Old 03-23-2011, 10:47 PM Thread Starter
JDG
Wow Thanks So Much David, Your Answer Was Super Helpful! Im going to give this a try! Thank you Thank you Thank you!!
JDG is offline
post #5 of 8 (permalink) Old 01-20-2014, 08:15 PM
Change the hoses today. Both were cracked. Thank you Davidtena. It was easy.
edsoto is offline
post #6 of 8 (permalink) Old 01-02-2015, 03:53 PM
i have an 01 sportage and the vacuum hoses for the four wheel drive is missing does anyone have a diagram or can someone tell me where they run to? thanks
kiassux is offline
post #7 of 8 (permalink) Old 01-02-2015, 04:07 PM
Drives: 2000 Kia Sportage EX, 2005 Volvo S60R
Quoted: 24 Post(s)
the second post in this thread says there is a nipple in the fender and a nipple on the back of the wheel and there should be an air line connecting the two.
where do you live? not ALL Sportages have the vacuum hubs
2000 Sportage EX, 4 door, 4x4, 5speed, Electric fan conversion 240k kms
tspot is offline
post #8 of 8 (permalink) Old 01-05-2015, 05:26 AM
Drives: Kia Sportage 2001
They might have installed the auto mechanical hubs .Put in 4 wheel and see if the front tires spin if they do you have to take it out of 4 wheel on the shifter then back up a little to disengage 4 wheel..
Unkel Kennie is offline
