2000 sportage won't start tried everything - Kia Forum
post #1 of 5 (permalink) Old 09-25-2010, 07:23 PM Thread Starter
Default 2000 sportage won't start tried everything
I have a 2000 sport age that will not start had code 1121 and fixed it still won't start checked fuel pump and filter both ok changed ignition coils and wires and spark plugs still won't start need...
hzyv6q is offline
post #2 of 5 (permalink) Old 09-25-2010, 11:10 PM
Pacosworld's Avatar
Drives: 1990 VW Corrado SC 1.8L, 2005 Kia Spectra EX
Quoted: 9 Post(s)
So when you say it won't start, do you mean it doesn't crank or it turns over, but just won't run? What did you do to fix the code P1121? Have you verified the fuel pump is actually pumping or checked the fuel pressure? Have you verified that you have spark? I know you replaced the parts, but it won't help if you don't have spark. What did you gap the plugs at? Whats the current mileage and has the timing belt been replaced before? Just need a basis on what you've done to diagnose this.
Mike AKA Paco
For US Kia service info Kiatechinfo
Pacosworld is offline
post #3 of 5 (permalink) Old 09-25-2010, 11:42 PM
DavesSpectra's Avatar
Quoted: 169 Post(s)
Nah.... It couldn't be a broken timing belt??? Or one that slipped a tooth?
You need to fill out the "User CP" area of your "profile" so we know generally where your from and what "version" Sportage you have...
ALSO.....
Do yourself a favor and READ the past posts on the Sportages....There is a wealth of information there on non-starting Sportages from flywheel pulley keys to bad grounds to timing belts to bad sensors.
There is no one "catch-all" repair suggestion to get you going again and "throwing" parts at the problem just gets costly.
After reading past posts THEN give us symptoms like posted and we"ll help you to get going again.
" Do it yourself" means just that...you have to read/check/post.
DavesSpectra is online now
post #4 of 5 (permalink) Old 10-09-2010, 01:13 PM Thread Starter
I have 90,000 miles and I'm located in Nashville . I do have spark and gas to engine . It will turn over but not catch turn over is good also got compression I think timing is ok I think it is a sensor somewhere had a p1112 fault for tcs but changed it also had hold light flashing
hzyv6q is offline
post #5 of 5 (permalink) Old 10-09-2010, 01:16 PM Thread Starter
I have 90,000 miles and I'm located in Nashville . I do have spark and gas to engine . It will turn over but not catch turn over is good also got compression I think timing is ok I think it is a sensor somewhere had a p1121 fault for tcs but changed it also had hold light flashing
hzyv6q is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
