No headlights - Kia Forum
post #1 of 7 (permalink) Old 09-07-2010, 07:29 PM Thread Starter
Default No headlights
I have a 1999 Kia Sportage 2wd. I was driving down the road, headlights flickered and stayed on. A few days later, headlights flickered and stayed off. My headlights will not come on now. I can turn parking lights on and turn signals. Bulbs are good, and relays are good. (new) Put a new multifunction/headlight switch in it, and still no headlights. Is it possible i got another bad switch? Or is there other issues? Also does anyone have a wiring diagram available?
jexjep00 is offline
post #2 of 7 (permalink) Old 09-08-2010, 08:01 AM
Drives: 2000 Kia, 2001 Jetta TDI
Greetings,
Headlight schematic attached. Wouldn't hurt to check the ground on that circuit at the headlights and put a fused jumper from v+ to that headlight relay output terminal. If the lights work from that test then check the relay ground and see if you have a v+ at the input of the relay with the light switch turned on. Just remember to use a fused jumper and that the relay and or circuit has the proper ground. A non fused jumper will burn through a harness is seconds. You won't know it until you smell it.
tlcstat
Name:	Headlight Schematic.jpg
tlcstat is offline
post #3 of 7 (permalink) Old 09-17-2010, 01:27 AM
arkansasfish's Avatar
Drives: 98 Sportage/ previously 01 Sportage
Gallery: 2
I used to have a van where if the emergency brake was pressed in just a tiny bit, it would cause the headlights to not come on. Does our KIA have any switches attached to the brake?
I own my second Sportage so I must really like em. I consider this one to be my second husband. Main issue with mine was the Timing Key(woodruff)
arkansasfish is offline
post #4 of 7 (permalink) Old 09-22-2010, 04:56 AM
try checking the wiring harness that plugs into the head light,both of mine were melted inside,cost me about $6 to fix.
Arbutus is offline
post #5 of 7 (permalink) Old 09-24-2010, 11:25 AM
Is your high-beam indicator coming on but the headlights are not? I had this problem and found the plugs that go onto the headlight bulbs to not have a good contact with the bulbs... I wiggled them and they would come on, and flicker... I suggest cleaning the contacts... they make contact cleaning sprays, but i use wd40 or pb and push the connectors on the bulb a few times...
Instanced is offline
post #6 of 7 (permalink) Old 09-30-2010, 09:18 AM
Drives: 2000 Sportage
I have a 2000 and just started having issues with the headlights. When I turn them on the high beam light comes on in low beam position. When I switch to high beam they go out. Am I looking at a headlight switch?
courtin is offline
post #7 of 7 (permalink) Old 10-17-2011, 04:06 AM
It turned out both of the headlight plugs needed to be replaced. Not a simple job for the passenger side without any room. Oh well it is done.
courtin is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
