Kia Gas engine sounds like a diesel.? - Kia Forum
post #1 of 13 (permalink) Old 08-01-2010, 06:20 PM Thread Starter
dj-vega's Avatar
Drives: Kia Sportage 1995 2.0 Dohc
Default Kia Gas engine sounds like a diesel.?
Hello.
Is it normal that KIA Sporty engine sounds a bit like a diesel engine? Mine really reminds me of a diesel compared to eg a 1.8L Volvo Engine. Is there a reason for this?
1995 Kia Sportage 2.0 4WD
Probably the most expensive 95 kia in my area...But who cares :P
dj-vega is offline
post #2 of 13 (permalink) Old 08-13-2010, 09:54 PM
Drives: Kia Sportage '96
also have the same problem... it just started 3 weeks ago.. theres this ticking sound when you start the engine and after pressing the gas pedal... very weird. some say it has something to do with the tappets that needs to be adjusted. but i know for sure that it doesnt suppose to sound like that. do we have the same issue?
can someone please shed some light on this?
topher is offline
post #3 of 13 (permalink) Old 08-14-2010, 01:08 AM
Drives: 1999 Sportage A/T 4WD
Quoted: 7 Post(s)
If it comes from the tappets I think it could be a lack in the lubrification. You should use a good oil, I think the best for my Sportage DOHC engine is 5-40W, change it every 10,000 Km or every six months, and replace the oil filter preferably with the original oil filter from KIA. But if you have used mineral oil it is better that you don't switch immediately to synthetic oil, but you should use half-synthetic oil (10-40W) before switching to synthetic oil (5-40W).
But before using half-systhetic or synthetic oil check if the engine of your car can use them, because I am referring to my '00 Sportage DOHC engine and I don't know what engine there is on your '96 Sportage.
Galf is online now
post #4 of 13 (permalink) Old 08-14-2010, 02:12 AM
i thought of that and only added mineral oil/ordinary havoline oil, but with no luck. im still hoping it could change if i change the oil completely and replace the filter. my dilemma though is, if it doesnt work and tappets needs to be adjusted, i would have to change the oil entirely again as it will be contaminated.
so you think i should have the tappets checked first then change oil?
or try to change oil and filter and hope it works out? but with the possibility of tappet adjustment and another change oil?
topher is offline
post #5 of 13 (permalink) Old 08-14-2010, 12:22 PM
Quoted: 7 Post(s)
I would replace the oil with half-synthetic oil 10-40W and the oil filter with the original oil filter from KIA. After 10,000 Km or six months I would replace again the oil with completely synthetic oil 5-40W and the oil filter with the original oil filter from KIA.
I have checked on Castrol web site: your Sportage can use 5-40W synthetic oil.
Galf is online now
post #6 of 13 (permalink) Old 08-16-2010, 07:42 AM Thread Starter
dj-vega's Avatar
Hello.
I just started up my Kia. It had a ticking noise today. Other times it starting up without any ticking noise, do you are experiencing the same thing, ( that the ticking sound comes and goes.?)
dj-vega is offline
post #7 of 13 (permalink) Old 08-17-2010, 12:55 AM
i have others saying it comes from the valves... il have mine checked within the week. i'll keep you posted.
topher is offline
post #8 of 13 (permalink) Old 08-20-2010, 11:11 AM
Drives: 2001 kia sportage
it might be a result of hot climate - on my sportage we had the same pronlem when summer came- some severe tappet noise occured, especially on start up. an oil change to 10/40 solved the problem. plus make sure your oil level is correct
hadtomer is offline
post #9 of 13 (permalink) Old 08-20-2010, 05:19 PM Thread Starter
dj-vega's Avatar
I use the 10-30 oil. Thats what the owners manual says.
dj-vega is offline
post #10 of 13 (permalink) Old 08-28-2010, 09:34 AM
after an engine flush, change oil (ordinary mineral oil) and change the oil filter. the tapping noise went away!!!!
BUT... there's this huge cloud of white smoke now every morning. I checked the oil level and its normal... any guess? i dont think there's a new problem, but maybe some oil went to something? help please.
topher is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
