Evaporative System Monitor and Exhaust Gas Recirculation (EGR) Monitor - not ready - Kia Forum
post #1 of 16 (permalink) Old 06-04-2010, 08:47 PM Thread Starter
Drives: 1997 Kia Sportage, 1996 Ford Explored Eddie Bauer
Default Evaporative System Monitor and Exhaust Gas Recirculation (EGR) Monitor - not ready
Hey, this is my second post of the day!
Last week I decided to connect the OBD2 reader just to see if everything was fine (I will need to smog the car in a couple months). My check engine light was off, and has been off for almost half a year (yeee!). But for my surprise, the reader pulled a code anyways, a P0440, evaporative emission control system malfunction. I deleted the code, and decided to wait to see if the code would come back before following the kiatechinfo instructions for this code. The next day, after driving around 30 miles, I checked the codes again. The CEL was off and there were no codes stored, but the reader could not check the Evaporative System Monitor and Exhaust Gas Recirculation (EGR) Monitor. The reader said that both systems were not ready and that I had to drive the car longer. Fair enough. I drove around 800 miles during the holiday (you guys have to check Mammoth Lakes in California and the Sonora Pass, it is awsome). However, the same problem persists. CEL off, no codes, but the Evaporative System Monitor and Exhaust Gas Recirculation (EGR) Monitor are not ready.
Now that the problem has been stated, let's go for the questions!
Why in hell the systems are not ready?
What should I test?
Could this be a problem for the smog test?
Thanks for the help and patience!
Dididavis
PS: Sorry about the long post!
dididavis is offline
post #2 of 16 (permalink) Old 06-04-2010, 08:52 PM
Pacosworld's Avatar
Drives: 1990 VW Corrado SC 1.8L, 1999 Kia Sephia, 2005 Kia Spectra EX
Quoted: 9 Post(s)
Hopefully this helps
1997 Sportage Drive Cycle
Not sure why the systems aren't ready, but you may try this to get it to complete. As far as smog, they probably run the drive cycle to get any pertinent issues to pop up. My Caravan never showed the CEL before I smogged it and the smog center got it to come up with an EGR code that had to fixed before certifying it.
Mike AKA Paco
Pacosworld is offline
post #3 of 16 (permalink) Old 06-04-2010, 09:26 PM
Drives: 96 4 DOOR 4WD SPORTAGE, 2000 2WD 2DOOR SPORTAGE, Mazda 3
Quoted: 9 Post(s)
I hope you're ok with that one not ready, because I changed my computer and drove over to Manteca (Bass Pro Shops) and back and I have the same issue. No CEL but the same system hasn't checked yet.
Rather than running a code reader, I got a usb interface and hook up my netbook with a OBD freeware program.
I believe that you are allowed 1. Will let you know next week.
UPYOURKIA
White 96,4x4 w/Y2K motor,Warn man.hubs,K&N filter, 3row rad., twin 16" electric fans w/SPAL FAN-PWM, 1.4" body lift, 4" UPYOURKIA lift kit,265 75-16 TREADWRIGHT GUARD DOG TIRES ON 16" DC-2 wheels, 140 amp alt. dual batts.
upyourkia is offline
post #4 of 16 (permalink) Old 06-07-2010, 02:58 PM
aquanaut20's Avatar
Quoted: 43 Post(s)
If any of the OBD self tests (ready monitors) do not clear, the test will not continue regardless of drive cycle.
You must first find and rectify the evap system monitor system, most times a poorly sealing gas cap.
What was the specific code??
aquanaut20 is offline
post #5 of 16 (permalink) Old 06-14-2010, 11:42 PM Thread Starter
Thank you for all your replies.
Two systems/monitors are still not checking, the Evaporative System Monitor and the Exhaust Gas Recirculation (EGR) Monitor. The P0440 code had not come back, and no other codes are present. I did not try the drive cycle that Pacosworld suggested, should I try it?
Upyourkia, how did your smog test go? I am curious about the usb interface. Where did you find an ALDL/USB cable?
Aquanaut20, welcome and thank you for your input. My gas cap seems to work fine, but since it is not so expensive I might try to replace it. Would a bad gas cap make the systems not ready?
Thank you,
Dididavis
post #6 of 16 (permalink) Old 06-16-2010, 12:39 PM
aquanaut20's Avatar
Quoted: 43 Post(s)
Originally Posted by dididavis View Post
~Snip~
Thank you,
Dididavis
The gas cap is an essential part of the EVAP system, it has a pressure relief valve built in (gets dust inside the valve seat and leaks) , and a rubber seal. The least you should do is have it tested.
If the EVAP test does not complete the ECU/CPM will stall and will not complete any other Monitor (self test) functions.
post #7 of 16 (permalink) Old 07-08-2010, 01:43 PM
Originally Posted by aquanaut20 View Post
exhaust The gas cap is an essential part of the EVAP system, it has a pressure relief valve built in (gets dust inside the valve seat and leaks) , and a rubber seal. The least you should do is have it tested.
I had the same problem but didn't know much about the EVAP test and went ahead with everything connected with it. I just blew it and it's still in the shop.
gordonjj is offline
post #8 of 16 (permalink) Old 07-08-2010, 02:17 PM
Quoted: 9 Post(s)
Sorry, didn't see the question to me. Well, haven't had time to get it checked. Trying to sell my 97 4dr 4wd. I will try and find out what the allowance is. I got the usb interface cable off ebay. Their software wouldn't load but it works with other free and purchased software.
Keep us posted and I'll try and find out about the not ready state/allowance.
UPYOURKIA
post #9 of 16 (permalink) Old 07-08-2010, 06:24 PM Thread Starter
Thansk UPYOURKIA, that will be a very useful information.
I did not know that my gas tank was leaking when I created this post. Maybe the leak is causing the problem with the EVAP readiness, not the gas cap. Anyways, I need to fix the tank before looking at other things.
Are you selling you Sportage? My brother is looking for a 4wd, but he is not so excited about a Sportage due to all the problems that I had with mine. But I will tell him though.
post #10 of 16 (permalink) Old 07-17-2010, 05:19 PM
Drives: 2001 Sportage, 87 Honda Magna
my 2001 sportage is telling me that my cat monitor, evap monitor, and o2 monitors won,t complete test cycle, before i drove it it coded for no coolant temp from ecu to tcm, i cleared it but it runs so badly i havent driven it for more than a block so i don't know if it will recode or not, checked the sensor, and it seems ok, any ideas?
ddhowlan is offline
Quick Reply
You may post new threads
You may post replies
