Check engine light stays on ALL the time - Kia Forum
post #1 of 6 (permalink) Old 02-19-2010, 01:04 PM Thread Starter
Drives: 2001 Kia Sportage
Default Check engine light stays on ALL the time
It says thermostat, but it's been replaced.
Ladycat27 is offline
post #2 of 6 (permalink) Old 02-19-2010, 01:08 PM
Drives: 2010 Kia Soul, 1994 Ford Ranger
LOL, Need more info then that, there are no codes that say's that the thermistat specifically is bad. So let us know the exact code and maybe we can break it down from there............
WOOLLFF is offline
post #3 of 6 (permalink) Old 02-19-2010, 01:18 PM
Was it P0128?
mattybyzf is offline
post #4 of 6 (permalink) Old 02-19-2010, 07:11 PM
Has the thermostat been replaced with a part from the dealer? Aftermarket t-stats are designed different and will not allow the engine to heat up in the predetermined time. If it is a Kia t-stat I have seen that the cooling fan clutch gets worn and will not allow the fan to "free wheel" properly when cold, not allowing the engine to warm up fast enough
cdavis is offline
post #5 of 6 (permalink) Old 02-21-2010, 06:38 PM
Drives: 2002 sportage 4x4 manual
Take negative off battery for 10 minutes then replace , code may not have reset after thermo replace , just a guess. You'll have to reset clock and radio
frmelnyk is offline
post #6 of 6 (permalink) Old 02-22-2010, 11:09 AM
I agree. The other thing if you did replace the t-stat make sure it is the correct t-stat(best to use kia's), also make sure your coolant mixture is good (I am sure you replaced the coolant when you put a new t-stat in....)
WOOLLFF is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
