catalytic converter trouble
I have a 01 kia sportage, 4 wheel drive, automatic. The bottom catalytic converter was clogged so I had it replaced. I changed the upper and lower Oxygen sensors. When I took the heat shield off the exhaust manifold, I saw that the exhaust manifold was cracked, so I replaced it. When I removed the old manifold, I checked the upper catalytic converter and saw that it was bad, too (the ceramic was actually melted). So, obviously, I replaced it.
So now that I've replaced this stuff (2 converters, 2 O2 sensors, and the exhaust manifold), is there anything else I should replace or do to prevent this from happening again? I was told that the reason these parts failed in the first place was because the engine wasn't running right. Is it possible that when the bottom converter clogged up, it caused the extra heat to damage the parts above it? If so, what caused the bottom converter to clog up to begin with?
Any ideas on this situation would sure be helpful! Thanks, Pat
