Originally Posted by kiaracer
i didn't see him state that he had the a/c on or off so i don't see how you can be the quick to assume that's the problem.
i would take a look at your heater hoses and make sure they aren't leaking coolant.
Well, it's like assuming a lot of automotive problems over the internet, one can never be absolutely sure. Coolant is never clear and since he just had the thermostat repaired, I did assume the engine had fresh antifreeze in the system. I also assumed the hoses were checked for leaks at that time, which is a standard practice when servicing the cooling system. The leak would also have produced the very distinctive sweet odor of antifreeze if dripping off a hot engine which most people mention, and Patrick 2005 did not. A slow drip of condensation off the condenser unit after running the engine for a few minutes made sense to me.
Patrick2005, does this car have automatic climate control?
