Old 03-15-2009, 09:08 AM   #1 (permalink)
Patrick2005
Drives: 02 Kia Sportage 2 Dr 4WD
Default Idle Problem
I just changed my spark plugs yesterday with NGK Iridiums and now that everything is back together, the engine is kinda spitting and sputtering. Can anyone help me figure this out?
Patrick2005 is offline   Reply With Quote
Old 03-15-2009, 10:16 AM   #2 (permalink)
Pacosworld
Pacosworld's Avatar
Drives: 1990 VW Corrado Supercharged 1.8L, 2000 Dodge Grand Caravan
Recheck the spark plug gap. Was it sputtering before you changed the plugs?
Pacosworld is offline   Reply With Quote
Old 03-15-2009, 05:52 PM   #3 (permalink)
tlstotelmyer
I would check to make sure you dont have the wires going to the wrong plugs as well.
tlstotelmyer is offline   Reply With Quote
Old 03-15-2009, 06:06 PM   #4 (permalink)
Patrick2005
no it never sputtered before i changed them. I gapped all of them to the spec 1.0-1.1 mm
Old 03-15-2009, 06:21 PM   #5 (permalink)
ron1004
Drives: Kia Elan
Try gapping them at 0.75mm (0.028 ~ 0.030").
It appears that the gap is incorrectly stated (1.0-1.1mm) in some literature.
Old 03-15-2009, 06:47 PM   #6 (permalink)
Patrick2005
I tried putting the old plugs back in and that didn't help. I have a check engine light on which one reason is my coolant temp sensor but I knew that was bad. the other code is mass air sensor low input. what exactly does that mean and would that cause my problem?
Old 03-15-2009, 06:56 PM   #7 (permalink)
DonM
Drives: 2002 Kia Sportage, 2001 Daewoo Lanos
MAF (mass air flow) sensor going bad will definitely cause the engine to run rough. Changing spark plugs was probably just coincidental.
DonM is offline   Reply With Quote
Old 03-15-2009, 08:10 PM   #8 (permalink)
ron1004
Drives: Kia Elan
Check the integrity of the large bore flexible pipe between the MAF and the throttle body - possibly a leak in that section is causing a lower than normal MAF signal.
Old 03-15-2009, 10:32 PM   #9 (permalink)
Patrick2005
I looked up how to test the MAF so I will check it out and see if thats it. I thought at first the coils weren't seated right on the plugs but I pulled them off and put them back on again and still the same thing happens. not sure if its missing or not because the check engine light isn't flashing, plus I didn't get any misfire codes.
