From my manual on CD (1995 - 2002 models).
INSPECTION AND ADJUSTMENT
Clutch Pedal Height
Inspection
Pull back carpet and measure the distance from the
upper surface of the pedal pad to the bulkhead.
Standard height: 9.84 in (250 mm)
Adjustment
1. Adjust the clutch pedal height by loosening the lock
nut and turning stop bolt.
2. After the adjustment, tighten locknut.
Tighten nut to 12 lb.'ft (16 N.m).
Clutch Pedal Free Play
Inspection
Push the clutch pedal lightly by hand and measure the
free play.
Free play: 0.5 in (12.7 mm)
Adjustment
1. Adjust the freeplay by loosening locknut and
tuming the pushrod.
2. Check that the distance from the floor to the center
of the upper surface of the pedal pad is correct
when the pedal is fully extended. If it is not within
specification, adjust.
3. When correctly adjusted tighten locknut.
Disengagement height: 7.25i n (184m m).
Hope that helps but if you need a manual - I have a cd (1995 to 2002 models) that I can do you for £5 GBP (8$usa) and that includes postage to just cover costs if it helps you, payable via paypal as they do automatic currency exchange. Let me know on
Philsbargainstore@gmail.com (pay to that address with paypal). Regards and good luck.
