Originally Posted by sellin
…get back down under 60 and it starts running fine again lights go back to normal. I am at a total blank and was hoping that maybe some of you guys might know what the problem is. Thanks again.
OK, first determine if this is problem of speed or engine revolutions.
Drive it to 60 notice what rpm it is. Then slow down, and do kick downshift and see if high rpm is fine. Let it go to 60 or more.
I think it will be more related to speed. I do not know what sensors might be making problems.... BUT I would search for any loose cables. It sounds to me like maybe some (from alternator, battery, or ECM) wires are loose and when speed is high enough pressure of air pushes it/them to loose connection.
Its hard to say without more details, inspection and so on.
