What can anyone tell me about the egr ststem.
have a check engine light on. code says egr system leak.
real doggy, does not like hills, 60 mph top on the highway, flat ground
The EGR valve directs exhaust gas into the inlet manifold under certain engine operating conditions, but if it does not shut off well it causes performamce issues.
Check the web site in my sig and you find a lot more info in the "Shop" section.
__________________ For service info register (free) with KiaTechInfo and click on 'Shop' on the left, and for elect schematics click on 'ETM'.
Thanks, I will check it out.
I will post my answer, when / if I find the problem.
Has any one else had issues with this? kinda new to the egr sytem
I do most of my own work, but have yet to tamper with the egr stuff.
Not sure if it has anything to do with my issue, but if I come to a slow gentle stop, I idle around 1,300 rpm. If I stop hard (pitching the nose down) The idle returns to normal.
Any posibilities of being associated with the egr stuff?
Often the exhaust gas directed into the inlet manifold by the EGR valve contaminates the ISC valve and it gets sticky resulting in erratic idle speed - best to take it off and clean it with carb cleaner.
Gallery:
0
the ports to the egr and/or the egr may need to be cleaned. a dirty egr valve can cause it not to close all the way. try to clean it and if it still doesn't fix it, it may need to be replaced.
hi all.. does the EGR valve might be my problem too?? sometimes when I accelerate the rev go up to 3000 on 20mph only then it will build up speed to change gear..
Welcome to the forum.
It would be impossible to make an informed guess with the little information you provide on your problem.
It could be the same problem, or a multitude of other possibilities such as vacuum leak, choked fuel filter, bad spark plugs, ............
hi.. thanks for fast reply... it just happen this month, i have it maintenance last november change the oil/oil filter/fuel filter/sparkplugs/transmission oil and all is fine until then i notice when having to stop on traffic and accelerate, i have to push hard to the pedal and the rev just go to 3000 only on 1st gear then it will speed up to shift gear.. what might be causing this?? wrong sparkplug?
