2000 Sportage no start update
Well it seems that when It was overheated this second time the rings must have lost tension It has 110,000 miles. I did a compression check and no compression on 1&3 cyls. Then did a wet test and had compression I don't know If the block may be ruined or not It looked great The head has been completly rebuilt. What is the best way to go on this 2.0 engine overhaul or replace the short block? most machine shops around here will not even work on the overhead cam heads.You mention KIA to them and they say no way I have to order every last part for this thing nobody stocks anything for a KIA.
thanks
Steve
