Old 08-05-2008, 05:54 PM   #1 (permalink)
roknrll
Drives: 2000 Kia Sportage EX
Default Low idle misfire?
Hello; I'm not new to the forums, I had to change my registration because I forgot my password and have since changed my E-mail address so anyway. I have a 2000 Sportage EX and I have a misfire when I pull away from a stoplight or after backing up. Its when the RPM's drop below 1000. If I keep my foot on the gas and keep the RPM's up, it runs fine.
Here's the list of things I've replaced;
1) both coils, coil harness, plugs & plug wires (gaped at 30, then 40 no change)
2) battery
3) alternator
4) fuel pump, filter, pressure regulator
5) radiator, all hoses & heater core (unrelated but worth mentioning)
6) replaced belt driven fan with electric
7) Head resurfaced, valve job, head gasket
8) timing belt and water pump
9) added a rear swaybar and KYB shocks & struts (also unrelated, but fun)
I keep getting the famous MIL's;
P0300
P0302
P0304
They will go away for awhile then come back on. This thing is killing me, I hate spending more money on this car. Does anyone have any ideas?
Any ideas would be greatly appretiated. Thanks again. KZ
roknrll is offline   Reply With Quote
Old 08-07-2008, 04:29 PM   #2 (permalink)
roknrll
Old 08-08-2008, 09:39 AM   #3 (permalink)
Mike70
Drives: 1999 Kia Sportage
Some things to look at: Idle air valve, throttle body, injectors. Maybe ry cleaning all of them and see if it improves. Also clean the MAF.
Mike
Mike70 is offline   Reply With Quote
Old 08-11-2008, 03:24 PM   #4 (permalink)
Mike70
Also the O2 sensor(s). Have they been changed? Just guessing here.....
Old 08-11-2008, 09:23 PM   #5 (permalink)
roknrll
10) changed (before and after cat) O2 sensors (sorry forgot to list before) Just give me a short block and I've got a new motor. Where is the IAV? I'ts odd because it's only when you dip below 1000 RPM. If I sit at a light and drive two footed and keep the RPM's up while its in gear, It pulls away strong.
Old 08-12-2008, 10:16 AM   #6 (permalink)
Mike70
The idle air valve is on the pipe going between the air filter and the throttle body, about halfway I think. The MAF is first, then the idle valve.
Old 08-12-2008, 11:39 AM   #7 (permalink)
ron1004
Drives: Kia Elan
That right.
Item 6 on this picture.
http://www.kiatechinfo.com/data/manu...ENG/22_05a.gif
The Idle Air Control valve would cause idle speed problems, but not misfire.
For the misfire I'd look at the coils, coil wires and spark plugs.
Have you check the 'DTC' section on the KiaTech web site - they suggest things like vacuum leak and possibly bad PCV tec. some of which I would not have considered would cause misfire.
Old 08-12-2008, 11:43 AM   #8 (permalink)
Chicago
Make sure your gas cap is on tight and it has a good seal. I know that sounds stupid but trust me, it's a big deal on the Sporty. Search the forum for "Gas Cap".
Chicago is offline   Reply With Quote
Old 08-12-2008, 11:51 AM   #9 (permalink)
ron1004
Drives: Kia Elan
Worth checking, but I haven't heard of that causing a misfire.
Old 08-12-2008, 11:58 AM   #10 (permalink)
gator5
gator5's Avatar
Gallery: 5
Do a Fuel Injector clean first and see if the codes come back. If they do then start looking at the crankshaft sensor
2004 Kia Sorento
Tom Tom 720 GPS
Escort Radar detector
Front drilled and slotted rotors
K&N air filter
Chrome BMW kidney style grille
gator5 is offline   Reply With Quote
