Thanks for the response. Yes, I have tried that with no luck.
I pulled the two relays last night (fuel pump and main) and tested them; they're both good. Then with the ing sw in the on position I replaced them listening for the "click." The main clicked and the IAC started humming (normal as far as I know), but when I plugged the fuel relay in; no click. So I checked the voltage at the energize contacts and found 3v. One side to ground was 12 and the other to ground had 8.xx.
So I think I'm on the right track, but here's a twist. I jumpered past the relay and the fuel pump kicked on, but it still wouldn't start. So that 8v I'm seeing must be causing some other issues. I got the schematics from the tech site and will be tracing out the wires today. If any of this sounds familiar or you have any suggestions please chime in.
Also, just to add to the detail: It now seems to be doing this intermittently, not just when hot. I drove it yesterday with no issues and when I got home I shut it down and immediately restarted it without issue. 2hrs later it wouldn't start... So a short seems to fit the bill.
