Chuck
You can try this website for more info, just register (it's free), then choose ETM on the left side of the screen and put your info in at the top and click GO:
Kia Global Information System (KGIS)
NOTE: I have an 02 Conv and have found that sometimes the electrical diags are not present, so I just choose 2001 for the year and the info is usually there... that's how I found what I attached here.
From the looks of that diagram, I would think that the resistor is probably OK, since it works in the #1 position which means that the circuit is being completed through all three resistances shown. My guess would be that the problem is more likely the switch itself, or possibly the wiring between the switch and the resistor... but I'd bet on the switch being bad, since it is a "moving part" and they are always more suspicious (in my mind) than non-moving parts like wires... especially in this case when three wires would have to fail at once vs just one switch.
If possible, try just running a grounded wire to the each of the three positions (in turn) that are not working -- if each one works when touched with the grounded wire, then the switch is likely bad.
Harry
