Fuel Pressure problem - Kia Forum
post #1 of 10 (permalink) Old 04-02-2008, 09:43 AM Thread Starter
Default Fuel Pressure problem
I have a 99 sportage 5speed 4x4 the fuel pump does not come on when the key is turned to start.but i can jump it on the test plug under the hood,and it comes on but there isnt what i would call a strong stream of fuel.I checked and replaced the fuse(inside)and the relay in the main under the hood what would keep it from activating when the key is turned?
murry210 is offline
post #2 of 10 (permalink) Old 04-02-2008, 10:13 AM
Drives: 1999 Kia Sportage
Did you change the main relay also? I think the main relay feeds the fuel pump relay.
Mike70 is offline
post #3 of 10 (permalink) Old 04-02-2008, 10:18 AM Thread Starter
yes i changed the main still no change
murry210 is offline
post #4 of 10 (permalink) Old 04-02-2008, 11:31 AM
Drives: Kia Elan
Quoted: 96 Post(s)
Here's a schematic diagram from the web site in my sig.
The power to the fuel pump relay comes from the main relay and as you can see the jumper you used bypass the FP relay and FP fuse.
The ECU controls the FP relay - it should come on when you turn on the IGN switch, but if the CU does not see engine running within about 30 seconds it will take the power off.
Best to trace the power though using the diagram.
Although the fuel pump is capable of a fairly high discharge pressure, it doesn't have such a high flow rate - best to measure the rail pressure.
You could have a plugged main fuel filter or the pump suction strainer - most often the problem lies with the main fuel filter.
ron1004 is offline
post #5 of 10 (permalink) Old 04-02-2008, 12:13 PM Thread Starter
thanks i will give it a shot,see what happens.thanks for the feedback
murry210 is offline
post #6 of 10 (permalink) Old 04-03-2008, 05:44 AM Thread Starter
the problem must be in the ecu,now i just have to find one at a reasonable price ha!ha! nothing on the car has been at a reasonable price
murry210 is offline
post #7 of 10 (permalink) Old 04-03-2008, 06:06 AM
Drives: Kia Elan
Quoted: 96 Post(s)
Not suggesting flaws in your fault finding, but be aware that the ECU's very rarely fail, so I'd be more inclined to think there's a wiring problem.
I would use a test wire and ground the wire that goes from the FP relay's coil to the ECU starting at the FP relay then down at the ECU's terminal.
ron1004 is offline
post #8 of 10 (permalink) Old 04-11-2008, 01:30 PM
bouttree's Avatar
Default i have ECU
I agree most likely not the ECU But I well sell my extra ECU My problem wasn't the ECU either. $50 e-mail tdellrod@juno.com
bouttree is offline
post #9 of 10 (permalink) Old 04-11-2008, 07:40 PM Thread Starter
I got the issue all sorted out,i went through every connection i could find and cleaned them as well as i could and what do you know it started working,thanks eveyone for your help
murry210 is offline
post #10 of 10 (permalink) Old 04-11-2008, 10:48 PM
Drives: Kia Elan
Quoted: 96 Post(s)
Good to hear you got it sorted and thanks for reporting back.
ron1004 is offline
