J
Are you sure that the timing belt was not damaged ?
If you are certain you did the timing belt gear allignment correctly (see below in italics), then, at this point, you really need to get/borrow a compression tester (maybe $30 at AutoZone) and test each cylinder -- pop out all four plugs; then test each cylinder in turn.
The key is to confirm that all four readings are approximately the same (+/- 10%) -- the actual values don't matter so much, though I'm guessing that they should be somewhere between 135 and 150.
7. After installing the belt make sure your alignment marks are set, the "I" on the intake ( left cam ) at 12 o' clock and facing the small dent on the timing cover backing plate and the "E" on the exhaust ( right cam ) aligned the same way as well and your crank cog marking ( woodruff key ) aligned to 12 o' clock and facing the small notch on the front of the block immediately behind the crank cog. There is also, most times, a small plate on the back of the crank cog that has a beveled notch in it and should be aligned with the woodruff pin, the two parts ( cog and plate ) are one part and move together so if you align the woodruff key at 12 o' clock, the notch should be aligned as well. Now might be a good time to disconnect your battery to allow the cam sensor to reset, it may not be necessary but its better safe than sorry.
Harry
