removing crankshaft pully from a 98?
hey, i have everything off to change my timing belt, but cannot get the crankshaft pully out. i borrowed a harmonic balancer puller from autozone and the bolts to screw in the crank arent near the right size. I went to lowes and got some M6x3" bolts and they wont screw in the crank.. Can i just use an impact and take the 21mm bolt out and pull the pulley off so i can change my timing belt?
thanks
nm im dumb just a few taps with a hammer and it came off
