AutoMechanical hubs installed, 2 1/2 questions!
OK, so I installed the Automechanical hubs from Warn. They were twice the price but I would rather have the 4WD instantly when I need it. No getting out to lock the hubs in a foot of snow.
It's a 2002, 4dr, automatic by the way.
Question 1: What is the best way to seal off the vacuum post/nipple (what ever it is called) on the back of the wheel?
I have the vacuum line there currently but since I know it will eventually crack I would rather have a more permenant solution.
1/2 Question: Is there a typical hardware item I might be able to pick up locally or even make to seal off the vacuum nipple at the wheel?
Question 2: Is anyone aware if the Automechanical hubs from Warn require you to back up the vehicle to disengage 4WD?
P.S. The 4WD seams to be working really well, I am waiting for the rain to make the ground really soft so I can go try it out.
