CarQuest does have, or can get, the gaskets for the Kia Sportage. At least for the 2002, which is what I have.
Other auto parts places may or may not carry the gaskets.
I flushed the cooling system in mine as the coolant looked rust color, and have had problems ever since. Mainly, it wants to overheat, and I have to keep a close watch on the temp guage.
I am thinking of pulling my radiator and using hose to try and back flush it. I have a second new thermostat on hand, as well as a few other related parts. The thermostat that was in it was stuck open when I pulled it out, freed up, but don't want to use it. Almost tempted to try it without thermostat like we did years ago. I specifically bought the 180 degree version.
May also try a new fan clutch, if I can get one reasonable. Another thought is getting an electric fan with more blades and better air flow than the one it has, and wiring it so I can turn it on full time from a switch as needed.
I had virtually no problems with an 82 Honda when I flushed and changed the coolant for the same reason, rust colored crap instead of good antifreeze.
