After a lots of hours of labour the problem of my 00 Sportage is finaly solve.
I have checked the fuel pressure, OK.
I replace the coils, plugs and wires, (crack in coils)
I have checked the timing belt and the key on the crankshaft, OK.
I have checked the ECM pins, B+, ign, and ground, OK
The engine won't rev. over 3500 RPM but idle well. I still have the misfire and codes P0300 P0302 P0303
I decide to remove the O2 sensor from the engine manifold.
While the engine is running i see something moving in the hole.
The first catalytic converter was broken and some pieces blocked the second catalytic converter under the car.
After i have remove all the ceramic of the converters. Now the engine run like a Swiss Watch with all is power back.
Now the only thing remaining is to purchase all these expensive parts.
Jacques
