Emissions/vacuum hose routings
I have a 1995 Sportage, 2.0L, SOHC, 5 speed. Can anyone post a diagram or chart for the emission/vacuum hose routings underhood. There's a vacuum/electric switch/solenoid mounted on the front passenger face of the upper intake plenum, as well as some small tubes under the upper intake plenum. Some hoses are connected, some are not. Some are plugged off. This vehicle runs well, but at times it stumbles when driving at a steady speed. Does OK on acceleration and decelleration. (Sort of like an old point- type vehicle with the points set too close). Turning the vehicle off and restarting usually clears up the problem until the next drive cycle. Engine operating temperature (cold or hot) does not seem to make a difference. Cold start is OK, and continues to run after a cold start. Sometimes idle will fluctuate, or go to a low idle (like it's loading up), but this is not a for certain thing every time the vehicle is used. Fuel mileage is about 20 mpg for a 25 mile trip (road). Any ideas or help is appreciated. Thanks, David
