Old 01-17-2008, 08:54 AM   #1 (permalink)
chasmay1
Angry Transmission problems
Have a 2002 Sportage 4wd 5 speed with 151k miles. It makes a loud whining noise in all gears. The faster I go the louder it gets. It goes away when clutch is pushed. Thought it might be throwout bearing< so I just replaced throwout and pilot bearings, clutch and pressure plate. Put tranny back on last night and still have same problem with the whining. Thinking I need to replace tranny now. Does any one know of a reputable rebuilt transmission dealer? Or does anyone have any ideas of what else it might be?
Thanks,
Chuck
Winchester, Va
chasmay1 is offline   Reply With Quote
Old 01-17-2008, 09:14 AM   #2 (permalink)
cmhj2000
cmhj2000's Avatar
Drives: 09 Cobalt
Pushing in the clutch and the noise going away would suggest trany issues. Before I'd toss the trany I'd give the input shaft and bearing a look over as well as the output shaft and bearings.
Sometimes the whine is internal, be it a cluster shaft issue or even a seperate bearing/gear issue and other times I've seen input/output shaft shaft issues. Also low gear lube or worn out gear lube can have a big effect.
A big guess from this vantage point but just some food for thought.
cmhj2000 is offline   Reply With Quote
Old 01-17-2008, 09:47 AM   #3 (permalink)
chasmay1
While transmission was out,we inspected the shaft. It didnt look worn and it turned smoothly. We also drained the tranny and put in new fluid.
Old 01-28-2008, 12:20 PM   #4 (permalink)
EGrier
Hello chasmay,
I am having the same problem with my 98 Sportage. Only it stops whining when I am in 4th gear. Let me know if you come across a cure and I will do the same.
EGrier is offline   Reply With Quote
