1996 Sportage Timing Belt, etc.
My Daughter's Sportage started running really poorly and while I know something about cars the Kia engine is new to me, so I have a few Nubie questions I hope this board can help with.
The car will start but sounds like it running on 2 cylinders. There's no metal knocking sounds, but there is a lot of whitish smoke coming out the back and I suspect it's gas smoke, not water. I'll know better after I get the plugs out.
I'd thought I'd check the timing belt since we have no history on it and it could be due for a replacement. I took the air plenum off and removed most of the timing belt cover bolts, then noticed that the thermostat housing needed to come off, so I removed those nuts and tried to pull it off but now I see I have to pull the fan and shroud first.
I was able to pull the cover back and see the belt and cam pulleys. The belt doesn't look trashed, or even particularly worn. I took 2 wrenches and turned the cams CW at the same time so the timing marks lined up and they seem to be timed to each other as they should.
I turned one cam pulley back the other way a bit and the belt went really slack. I'd say it has about .5" of up and down motion in the middle now. I don't know if this is because the tensioners relaxed and now are not applying a the same amount of tension to the belt or what? Whatever the case I'll know more once I get in there.
If the belt slipped, do they ever slip at the crank and not at the cams ?
If I want to remove the spark plugs do I start by removing the aluminum intake tube and then every thing else on top of the engine ?
Thanks for any help!
1996 Sportage 2.0L
