I mean 4WD High-- I was a bit backwards when I made the comment, but I read the manual before I did anything...and indeed, 4WD H --- Which in my eyes indicates 4WD part time even I though I realize that KIA has the auto-hubs.
And the more I read, the more I see that your reply is right on track.
History: when I bought the kia, I was told by my 'friend mechanic' that the vacuum lines for the abs (which obviously these are for the 4WD) were shot. He replaced them before we left the car lot with a smaller tube. The line size may be fine, but the fact that they were bad at one time indicates stress to that area.
I bought the KIA with the dealership stating that the 4WD and brakes needed work. The brakes have a warped rotor (pretty smooth rotors, but they shimmy when brakes applied). Could this also indicate a premature bearing failure which also ties back to the 4WD hubs?.
I did not know that the Hubs existed until yesterday when I began to research sportage issues. I will indeed clean, repack the hubs, and likely replace the vacuum lines with a bit larger tubing.
Thanks so much,
