2001 sportage has me stumped.
Hey all, I'm new here. My sister has a 2001 sportage. It idles fine. When you push on the gas it falls on it's face. The RPMs rev but it won't gain speed, it has no power. It used to gradually gain speed or you could stop and sit for a few minutes and it would run a little bit. Now it will just idle. It is reading P0302(cylinder 2 misfire), P0300(random/multiple cylinder misfire), and P0304(cylinder 4 misfire). We have changed the fuel pump, fuel filter, plugs, plug wires, coil packs, and the timing belt looks new. We pulled the plugs and only one was firing and #4 was oil soaked on the firing side. This thing is starting to drive me crazy. Does anyone know what could be the issue? Thanks in advance for any advice.
