Hie to you all. I am a newbie and hope I am posting this at the right place.
I have a Kia Sportage 2.0 (DOHC 1995). The ABS light in the dash is permanently on. I did the flashing test as specified by GDS and got the ABS light on the dash flashing 7 times repeatedly. After which I started searching for the ABS Control Unit because the ABS-7 error code says I should check the ABS Control Unit and I can NOT find it. Where is it? I found the ABS Relay in the dash under the steering wheel alongside relays for: the Indicators Relay, Hazard Relay, Horn Relay BUT found NO ABS Control Unit.
Where can I find the ABS Control Unit and what does it look like
Thanx a lot in advance, for the help.
