Old 07-07-2007, 02:33 PM   #1 (permalink)
vic
Question Hold Warning light?
I have a 97 Sportage and a few weeks ago the check engine light (solid yellow) and the hold light (blinking yellow) came on. I was reading the manual and it said that the hold indicator "indicates that the Automatic Transmission is in HOLD mode"? That's it. What is this means? Is this bad? Anyone had this problem? Any experts on this subject?
vic is offline   Reply With Quote
Old 07-10-2007, 02:00 PM   #2 (permalink)
entexman
I have the same problem. I took my Kia to my trusted neighborhood mechanic and he read these 2 codes from my 97 Kia Sportage:
P0101
entexman is offline   Reply With Quote
Old 07-10-2007, 02:06 PM   #3 (permalink)
entexman
P0101 - Air flow sensor warning
P00750 - Shift Solenoid Internal error
My mechanic told me he read these 2 technical postings by Kia:
TT089814-001 from Aug1998
TT029811-001 from Feb 1998
The TT02911-001 publication says something to the effect that the 2 codes are confusing to most technicians because they are unrelated and Kia says it is a wiring problem.
My mechanic said I should take the Kia to the dealership to fix the wiring problem.
Old 07-20-2007, 04:27 PM   #4 (permalink)
elarnol
I thought the hold light was something that the driver turns on (I know it's via a button on the gearshift in my car)?
elarnol is offline   Reply With Quote
Old 07-27-2007, 03:12 AM   #5 (permalink)
alaskabigdog
alaskabigdog's Avatar
The hold light indicates you have pressed the hold button on the shifter. This keeps the transmission in a higher gear than normal which helps in starting out in slippery or muddy conditions. Press the button again and the hold light should go off. The hold button is the lower button on the left side of the Automatic shifter.
alaskabigdog is offline   Reply With Quote
Old 07-27-2007, 11:01 AM   #6 (permalink)
luvmysporty
Default annoying Hold light!!!
so the same thing is going on in my Sporty.
Blinking hold light, and a steady check engine light.
Yet its running the same, despite the hold light being on and off
it shifts into overdrive like it should. From this topic, I guess its a wiring problem. Did you ever get that fixed? I think I'll just throw some stickers over the lights to get rid of them for now.
So did the dealer fix it for you?
was it just a wiring problem?
luvmysporty is offline   Reply With Quote
Old 07-31-2007, 03:38 PM   #7 (permalink)
TGWeasel
Drives: Sportage 2001
Exclamation Engine light, blinking hole and stutturing starter!
Unfortunately I am having the same issue as of lunch time. (VERY Depressing) I have a 2001 Sportage I bought 3 years ago. Never had a real serious problem with it until this year when I have to replace the battery alternator and spark plugs which I was expecting with as much as I drive it. I bought it with 15,000 and I have 86,000 on it now.
But the thing that got me upset is I tried starting it a few times and it wouldnt fire. It sounded like it was turning. I stopped sit for a minute and tried it a few more times before it finally fired. Now the check engine light is on and the HOLD light is blinking.
Is it safe to drive? I love my car and want to know how to do this myself if possible. Work is letting me borrow there truck so I am gonna leave my car here overnight.
I read somewhere that water on the trans controller connector could cause the erratic auto transmission operation. I drove through 4 storms of this weekend. I mean serious down pour till you can't see 10 feet in front of you. It did it again yesterday while I was at work. Then yesterday afternoon. it wouldnt start after two tries then the third it did. So I didn't think anything of it.
sorry for the long message. Any comments to help me out?
TGW
TGWeasel is offline   Reply With Quote
Old 09-12-2009, 12:32 PM   #8 (permalink)
CJ Kid
Drives: 1997 Kia Sportage, 2007 Kia Sportage
Default 97 Kia Sportage Blinking "HOLD" Light
I am having the same problem with my 97 Kia Sportage. Check engine light on and the "Hold" light blinking. Was just checking to see what others may have found out about what the problems were and what had to be done. Hoping maybe my local mechanic can solve it instead of going to the Kia dealership. Thanks for any responses.........
Erik
CJ Kid is offline   Reply With Quote
Old 09-12-2009, 04:26 PM   #9 (permalink)
pulsar86
pulsar86's Avatar
Drives: 2005 Kia Cerato sedan, 1986 Nissan Pulsar hatch
TGW
It definately sounds as if water has got into a connection in the wiring somewhere, if you work through any wiring connections under the car or low in the engine bay and seperate them and dry them out you will probably come across what is causing the starting problem. Electrics just don't mix well with water. Best of luck with it.
TAKE YOUR TIME, THINK IT OUT, DO IT RIGHT, DO IT ONCE!
pulsar86 is offline   Reply With Quote
Old 09-12-2009, 07:55 PM   #10 (permalink)
Baratacus
CJ kid revived this post, unfortunately most of these users don't even log on anymore so they won't benefit from any solutions we find.
Such as the blinking hold lite is the Transmission Control Modules way to tell you that it has generated a transmission trouble code and it is stored in the TCM. You can't pull the codes off of the ECM, you need to get them from the TCM and I don't know how to get the codes from there. Anyone know how to get the codes from the TCM?
Baratacus is offline   Reply With Quote
