What year is your sportage? There isn't any item to be serviced on the fan assembly according to the factory manual. It has a bimetal unit that senses the temperature of the radiator and a clutch allows it to stop turning when the vehicle engine speed is high enough. It definately sounds like the fan clutch is not operating propery. If the dealer did something to it and it's not working properly, take it back and ask to have it fixed. I've never heard of replacing any oil in them, could be a new one on me. The shop manual has no recommendation or specification for fan clutch oil. It does appear there maybe oil in the clutch unit, the manual says if it leaks, then replace the unit. Hope that helps.
