Old 01-29-2007, 04:55 PM   #1 (permalink)
loadder
Default 99 sportage missfire and bucks
already replaced the wires and plugs and coilpaks,
vehicle is hard to get goin but once you find the sweet spot with the gas pedal you can milk it up to speed then it seems to kick in and go just fine, but gettin up to speed can take a while, and dont even think of jumpin out in front of on coming vehicle, any help would be nice, dont know where to turn next or just take it to a shop and get milked there,
is it the fuel pump, or throttle sesnor. or cat converter clogged ?
loadder is offline   Reply With Quote
Old 01-29-2007, 09:05 PM   #2 (permalink)
Philmyster
Smile
sounds like converter clogged. Does your exhaust smell like rotten eggs. if so, its you converter.
Philmyster is offline   Reply With Quote
Old 01-29-2007, 09:57 PM   #3 (permalink)
Raven1210
Raven1210's Avatar
Gallery: 1
i would replace the fuel filter. Sounds like it mite be clogged. Is it running rough??
Old 01-30-2007, 06:54 PM   #4 (permalink)
loadder
Default yes it does
its has smelt since we got it, and yes it does run ruff, but only when trying to take off, once going, you can milk the pedal for the sweet spot and it takes off as normal
Old 01-30-2007, 08:33 PM   #5 (permalink)
Raven1210
Raven1210's Avatar
Gallery: 1
sounds like a fuel filter. You need alot of gas to get moving.
Old 01-30-2007, 10:27 PM   #6 (permalink)
mre_powers
mre_powers's Avatar
Drives: 00 sportage;96sable,vulcan
kinda sounds like timing is off like it jumped a cog.
got kia for free. mods are selective tree branch decoration right rear, warn hubs, k@n airfilter, aftermarket mp3 cd player. walmart brand
mre_powers is offline   Reply With Quote
Old 01-31-2007, 09:18 AM   #7 (permalink)
Raven1210
Raven1210's Avatar
Gallery: 1
Also can be a egr Valve
Old 02-01-2007, 08:03 PM   #8 (permalink)
maverick5.0
maverick5.0's Avatar
doble check the wiring harness that goes to both coil packs !!!!!! I had the same issues, loose coil pack harness, barely touching !!! I put zip ties to hold then in place at the connectors !!!! throtle body varnished-up or mass air sensor failier. hope this helps some, good luck !!!
maverick5.0 is offline   Reply With Quote
Old 02-05-2007, 03:13 PM   #9 (permalink)
loadder
Default darnit
checked connections on cdi's all good, changed the pcv , disconnected the battery , and the check lite went out, went around the block, all was good, still hesitating, so i drove it to the shop to try to get inspected today, got there all was still good , they put it in the bay hooked up the machine, and the light came on again , and thru a code saying miss fire in 4 ??????? what can i do next, the exhaust seems to leave the vehicle good, i guess the fuel filter is the next thing i can do, any suggestions on how to get that done???? thanks
Old 03-01-2007, 05:45 PM   #10 (permalink)
loadder
Default took it to school
local high school checked it out today and says number 2 has low compression , anyone know about changing the rings ??
