A littlw more info would be nice! under the oil filter cooler can be alot of things.
If you just changed the filter there is a chance the old o-ring was left behind causing the new filter to feel snug but with a massive gap, hense massive oil leek.
Also you could have cross threaded the oil filter, again making it feel snug but not sitting correctly.
You could have a crak in one of the cooler lines.
You could have a leak in the actual cooler it's self.
For both of the above you can bypass the cooler for now with a good lenghth of hose if you must.
There are a dozen other things it might be, like the valve cover gasket etc!
