Thr 'dragging' noise could be a loose heat shield on the exhaust, they are only spot welded in place and have a history of rusting loose, creating a rattle/grinding sound from the middle of the car, as for the bang i might be a loose or rusted thru exhaust mount, or the tail pipe could have rusted thru, another known issue with the sporty. If you hit a bump, turn a corner or lurch the car while shifting the exhaust will move possibly hitting the frame or body, the exhaust is held up at the rear by the tail pipe mount, if the tail pipe has gone south then there will be movement,.
