Originally Posted by Jools
Thanks for the reply. Where is it situated in the engine, the dealer said it is in the manifold and will cost £140 to sort
It is on the exhaust manifold, under the tin heat shield. Thay can seize in due to heat and corrosion so if you are looking at doing it yourself then be aware that there may be some issues. I would estimate for a replacement to be fitted it would be about 1/2-1 hours labour (realistically it is a 15 min job at best) plus the price of the O2 sensor. If you/they have trouble with it being seized/corroded in place then up to 2 hrs labour would be reasonable.
140 pound seems a bit on the expensive side...
This is one job you could wait while the dealer did it (more dificult to fudge the labour quote/costs with you looking over their shoulders). If you tell the dealer that it is located under the tin heat shield on the exhaust manifold (two bolts), connected with one electrical connector and is simply removed and replaced with an open-ended spanner, then it really gives them very little B.S. room, and shows that you know EXACTLY what they should be doing. Ask for an itemised quote listing seperate labour and parts costs. Assuming ~40 pounds/hr labour cost and 40 pounds for the O2 sensor you have just halved you bill.
..or less.
Let's see if we can't get this done for less than 60 pounds
