99 sportage auto tranny slips when cold
Ok i changed fluid and filter when this first started and fluid levels still good, even before this problem started it never tryed to shift into OD.
My owners manual does show a 4speed auto my shifter in the car shows
P,R,N,D,2,L no O.D. or button to shut OD off is this correct. My rpm's at 65 are right at 3000 rpm, 70 about 3200 i always wished it had a OD i did not buy this car new so didnt even think it had OD. it is a 2 door, 2wd with the half top if that changes anything. Ok can you recomend a good service manual i have looked everywhere but the dealer... cant find one. I do all my own maintenance and i have rebuilt a few auto trannys not foreign all american but cant be any different so not worried about that, but pretty sure its not inside. I dont have any codes or lights indicating a problem, just used my scanner to read any codes this week none , but do you need a different one to read the TCM ? Didnt know about a cold circuit for shifting could be my culprit do you know which senser it it using also where is this (splice in the loom ) i should look for. thanks for the help, this is getting interesting now..
