On Sephia I cleaned the remote contacts but that had no efect on the door lock/unlock problem.
After a visit at a KIA workshop, where the diagnose was a fault modul whitch is guite expensive (the diagnose the technican made-ODB was FALSE, the problem was not that module) I decided that i try to repair it myselfe, before waisting the money for his false diagnose.
The problem was on the ETACM, one of the lock/unlock relays was fault. I replaced the fault relay and the door lock is working again.
The relay is soldered to the ETACM (the relay to the midle of the board is the unlock relay the one to the side of the board is the lock relay). I make no waranty, that the replace could fix your doorlock problem. If you try this I take no responcebilities for what u are doing.
If you are unskilled in electrotehnics u shuden't do souch a repair becouse you may physically damage the ETACM so the car will be useles until you replace the ETACM-this would be expensive!!!.
Hope this will help somebody.
