Old 11-29-2006, 09:31 PM   #1 (permalink)
Overkillauto
Default Well finally think i figured it out VERY low vacuum
after taking the weekend off and mon,tues away from the kia i looked at it
i was asking myself what didnt i check
Engine vacuum
im getting about 10" at idle with no chance with any ports plugged up (brake booster, evap, pcv, etc)
I sprayed brake cleen around all gaskets and no change in idle so im sure its not a gasket leak
how can i tell if im looking at bad rings or just a valve job?
i took a vid of the gauge so you can get a better idea so let me know what you think
YouTube - vacume
Overkillauto is offline   Reply With Quote
Old 11-30-2006, 10:11 AM   #2 (permalink)
Damkia
Damkia's Avatar
A few from left field.......
leaking purge (carbon) canister?
vacuum hub solenoid broken?
Leaking resonance chambers (little black dangly bits along inlet manifold)?
IAC motor stuck open/leaking?
10" seems a bit low, (due to a leak rather than a blockage). Go through absolutely every vacuum hose attatched to the manifold and check thet they are not loose or perished both ends....
Old 11-30-2006, 04:51 PM   #3 (permalink)
Overkillauto
i had every thing going to the motor clamped shut expect the iac
Old 11-30-2006, 06:42 PM   #4 (permalink)
mgbgt1972
On the intake manifold there is a vaccum nipple that should have a cap on it, did you lose the cap? Sometimes you may not notice it's missing as it does not look out of place.
Old 11-30-2006, 10:59 PM   #5 (permalink)
Overkillauto
thats where im getting my vacume reading from
but the cap was there
Old 12-06-2006, 10:13 PM   #6 (permalink)
MECANO
Just an idea, a partly blocked exhaust (catalyser or muffler).The pressure is oppose to vacuum and give a constant low vacuum reading. But i don't know if it is common on Sportage? Trying to help.
MECANO is offline   Reply With Quote
