Originally posted by jdg29@May 21 2006, 01:32 PM
Which bolt to you pull to check the trans fliud in a 5 speed standard 2000 Kia Sportage? There's 2 on the side of the transmission.
Does anyone have any easy tips on how to remove the fuel filter? I tried pushing in the tabs and they won't push in. Also used various tools to try to push them in, but nothing seems to work.
Thanks for any help!
the best i can give you is push the connector as close to the filter then squeeze the tabs. DO NOT CUT THE LINES they are more then just rubber they are plastic. and to replace them costs 70$ and 2-3 day wait.
i suggest to try to clean them from all the dirt and greas build up. then try to squeeze them.
got kia for free. mods are selective tree branch decoration right rear, warn hubs, k@n airfilter, aftermarket mp3 cd player. walmart brand
