Consumer Reports.com - May 16, 2006
The potential for a gasoline leak in the 1996 to 2002 Kia Sportage has prompted an ongoing engineering analysis and investigation at the National Highway Traffic Safety Administration (NHTSA).
The analysis is examining the possibility that gasoline might leak from the "steel fuel storage tank on some models" of the Kia Sportage according to NHTSA.
The investigation was recently expanded to include any Kia Sportage using the same or similar steel gas tanks that are used to equip 1999 and 2000 model year vehicles.
Kia has reported to NHTSA the leaks appear to be the result of corrosion in the fuel containment and distribution system. Specifically, Kia has found corrosion in the protective coating around the fuel tank as well as the mounting plate for the unit that sends fuel tank information to gasoline gauge.
Kia is also investigating the corrosion problem and alleged defect.
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission.
