Originally posted by mhenry9885@Apr 17 2006, 05:14 PM
Sorted (although I must have had a death wish as I knocked the screws out and drilled new holes with a full tank of petrol)
I pulled the fuel sender out in an attempt to figure out why the fuel guage had broke, I found that the earth wire has completely melted on the sender inside the tank!. I've been told that it is possibly when I had a stainless steel exhaust welded on, they didn't put a surge protector on (its not been working since the exhaust was put on). Not sure myself but at least its working now.
I think we'll nominate you for the "Luckiest Man Alive" award, given out annually by the Norman Schwarzkopf Society (remember the Luckiest Iraqi Alive from Desert Storm)!!!
However, you were better off with more, rather than less fuel in the tank. A larger amount of fuel leaves less of the more volatile vapor available to ignite.
