Old 12-17-2005, 10:29 AM   #1 (permalink)
Pelo
Just bought a code reader and it reported the 1795 error code which is not in the book. Someone know what it mean ?
I bought a code reader because the check engine light was on, the HOLD light was flashing (this when I shifted to 4 wheels drive HI and then the transmission won't shift to overdrive) and the air bag light is always flashing 1 long and 5 short.
The air bag light is the only one I can't erase with the code reader. Any help will be appreciated, Thanks.
Pelo is offline   Reply With Quote
Old 12-17-2005, 08:04 PM   #2 (permalink)
rjmurph
4WD LOW SWITCH SIGNAL
Diagnostic Trouble Code
No. P1795 :
4WD Low Switch Signal Malfunction
Related Items :
· 4WD low switch signal line open short or disconnected.
Step
Inspection
Action
1
Inspect for wireopen, or short between TCM and 4WD low switch. Any problem detected?
Yes
Go to step 2.
No
Go to step 3.
2
Inspectshort to battery voltage between TCM and 4WD low switch. Repair if needed.
Replace 4WD low switch if no wire problem is found.
Go to step 3.
3
Using the Hi-Scan pro, record DTC "Freeze Frame" data. Erase DTC(s). Start engine and allow it to reach operating temperature, then road test vehicle using DTC "Freeze Frame" parameters (ECT, Vehicle Speed Load, etc.) Confirm that DTC(s) did not reoccur.
Yes
Go to step 3.
No
END.
rjmurph is offline   Reply With Quote
Old 12-17-2005, 10:35 PM   #3 (permalink)
Axe Man
As indicated that error code is a fault in the "4 wheel drive low" circuit.
You can't reset or diagnose the airbag system with the OBD-II scan tool. You need a Kia Pro Scan Tool and only dealers have that tool. So you need to have the dealer diagnose the airbag system.
Old 12-18-2005, 12:17 AM   #4 (permalink)
Pelo
Really nice answer, thanks to all, it is really the right place for Sportage owners. Quick answers, full details. With this, I should be able to start solving the problem.
As soon as I get the problem solved, I'll let you know.
