Here is a quick fix SOMETIMES.... Go to you favorite IdiotZone and get a small packet of dielectrical grease
2 take the connector off the TPS and clean it out with a scribe.pick,paperclip .....do this to both male and female ends
3 squize a small ammount into the connector
4 plug back in
5 disconect BATT for 5 min or so (this resets faults last reported to ECU)
6 re connect BATT and start ( important not to rev engine upon start)... The next few minutes are what the call BLM or Block Learn Mode....where th ecu is checking parameters and sensors
Just a simple test MIGHT EVENS SAVE $60 bucks
Good Luck
Tyson
Originally posted by DKElec@Sep 30 2005, 04:01 PM
Ok, the master cylinder was low.
I also got to Autozone, the code is...
P1124
Throttle Position Sensor Out Of Self Test Range
New sensor? Cost? Can I do it myself? Any guides? Thanks
